Scotbow Posted June 13, 2023 Share Posted June 13, 2023 I've used Stone slabs, (created with the 3D solids tool), as part of the exterior wall structure. However CA doesn't recognize the stone as a wall. Therefore no room definition, no floors, etc... When I try to connect between the stone slabs, using invisible walls, the invisible walls connect such that the internal layers of the existing exterior walls, are visible. Any ideas? Is there a way to make CA recognize the stone slabs, as wall sections? Thank you in advance, Scott Stonehenge.zip Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 13, 2023 Share Posted June 13, 2023 1 hour ago, Scotbow said: Is there a way to make CA recognize the stone slabs, as wall sections? NO. when one wishes to have a room, one uses walls or at least walls, invisible. Only then does one have a "Room Specification Dialog". DJP Link to comment Share on other sites More sharing options...
DBCooper Posted June 13, 2023 Share Posted June 13, 2023 You could try building the stone sections out of thick walls instead of solids. You won't be able to get the rounded corners doing this though, at least not easily. There may also be ways to solve the problems with the wall layers when using invisible walls, but you would have to post a plan/picture showing the problem. You might be able to get the look you want using doorways and then placing the blocks into them. Link to comment Share on other sites More sharing options...
