Rafters help - not sitting on carriers
SamPWB
4 minutes ago, robdyck said:
If you change the roof structure depth to 9 1/4", then select all the rafters, open and close the dialog box without changing anything, they will correct themselves.
Good call Rob.   Did you accomplish that in X14 or X15 ?   I tried in X14 and yes it does reframe but no birdsmouth ?
2 minutes ago, robdyck said:
x15 but I didn't look closely enough to notice that. Whoops...
No problem.  It works on the other side and I can't find any significant difference that would cause it to behave different.
