Hammer7 Posted June 1, 2023 Share Posted June 1, 2023 Does anyone know the solution for this error, the "check knowledge base" referred to a read only file, but I don't understand what to do with that? Link to comment Share on other sites More sharing options...
SHCanada2 Posted June 1, 2023 Share Posted June 1, 2023 if it is not supposed to be read only, you can click the properties of the file in windows explorer and change it to allow write privelges by user. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 1, 2023 Share Posted June 1, 2023 10 hours ago, Hammer7 said: Does anyone know the solution for this error, the "check knowledge base" referred to a read only file, but I don't understand what to do with that? Sounds like one for Tech Support , but it sounds like you no longer have Write Permissions to the Folder. Mick. Link to comment Share on other sites More sharing options...
