JanFriedli Posted May 26, 2023 Share Posted May 26, 2023 Say one has a long continuous walkthrough with say 1-2-3-4 keyframes that wastes a lot of travel time to get from say keyframe 2 to 3 where the travel from 2 to 3 is really not necessary from what one is trying to showcase but one is forced to because walkthroughs seemingly have to be one continuous path. To eliminate this unnecessary 2-3 segment is there a way to create two walkthroughs 1-to-2 and then combine the two walkthroughs so that one has a single video of the first 1-to-2 keyframe walkthrough and then the second 1-to-2 keyframe, which technically starts at the 3 location, so one can eliminate the 2-3 segment in one's video? Or is there a way to create a 1-2-3-4 keyframe walkthrough and then tell the program not to record anything in the 2-3 segment (i.e. jump to keyframe 3) and thereby essentially get the same result, i.e. a video that shows 1-2 and then shows 3-4 but leaves out 2-3? Link to comment Share on other sites More sharing options...
Chopsaw Posted May 26, 2023 Share Posted May 26, 2023 No Sorry. I don't think that can be done with Chief alone. You would need to use a 3rd party editor for that type of requirement. Link to comment Share on other sites More sharing options...
ProPlan_2011 Posted May 27, 2023 Share Posted May 27, 2023 You could set Keyframe 2's 'speed after' to the max 400ft/s. I suspect you won't notice the length between 2 and 3 at all while having only one walkthrough. Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 27, 2023 Share Posted May 27, 2023 12 hours ago, JanFriedli said: Say one has a long continuous walkthrough with say 1-2-3-4 keyframes that wastes a lot of travel time to get from say keyframe 2 to 3 where the travel from 2 to 3 is really not necessary from what one is trying to showcase but one is forced to because walkthroughs seemingly have to be one continuous path. To eliminate this unnecessary 2-3 segment is there a way to create two walkthroughs 1-to-2 and then combine the two walkthroughs so that one has a single video of the first 1-to-2 keyframe walkthrough and then the second 1-to-2 keyframe, which technically starts at the 3 location, so one can eliminate the 2-3 segment in one's video? Or is there a way to create a 1-2-3-4 keyframe walkthrough and then tell the program not to record anything in the 2-3 segment (i.e. jump to keyframe 3) and thereby essentially get the same result, i.e. a video that shows 1-2 and then shows 3-4 but leaves out 2-3? you can set your speed after and time for a specific keyframe to speed through a section Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 27, 2023 Share Posted May 27, 2023 14 hours ago, JanFriedli said: Say one has a long continuous walkthrough with say 1-2-3-4 keyframes that wastes a lot of travel time to get from say keyframe 2 to 3 where the travel from 2 to 3 is really not necessary If you find yourself struggling with walk throughs, you can always record your screen as you pan around, preferably with a space mouse. Then you can stitch together various clips and even create transitions between clips. The other option is to get acquainted with Twinmotion. It’s a lot easier to create videos with that software. Link to comment Share on other sites More sharing options...
JanFriedli Posted June 16, 2023 Author Share Posted June 16, 2023 Thanks everyone - will try all your recommendations. Link to comment Share on other sites More sharing options...
