5Design Posted May 15, 2023 Share Posted May 15, 2023 It's for a restau r ant remodel and will be built over the main bar at the entrance. I know I can find modelers on Upwork, but want someone who uses Chief, also. I also need the building modeled. I have pics and the floor plan. Need to add a vestibule like the entrance on the side where the fireplace is showing. email is terry@5designllc.com Thanks! Hula Hut Little Elm As-Built.pdf Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 15, 2023 Share Posted May 15, 2023 all I can say is "Good luck with all that" Link to comment Share on other sites More sharing options...
ericepv Posted May 15, 2023 Share Posted May 15, 2023 If a decent 3D symbol is available, I can help you out. Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 15, 2023 Share Posted May 15, 2023 1 hour ago, DRAWZILLA said: all I can say is "Good luck with all that" lost me at "upwork" Terry I don't know the type of work you do and the budgets you work with but as soon as someone mentions HGTV Fiverr Pinterest or Upwork I run for the hills. To me, and this is relating my own experience, you are saying that you want the lowest cost possible. To me, making that Titanic look the way you want it, is not a low cost endeavor. 1 2 Link to comment Share on other sites More sharing options...
5Design Posted May 15, 2023 Author Share Posted May 15, 2023 55 minutes ago, Renerabbitt said: lost me at "upwork" Terry I don't know the type of work you do and the budgets you work with but as soon as someone mentions HGTV Fiverr Pinterest or Upwork I run for the hills. To me, and this is relating my own experience, you are saying that you want the lowest cost possible. To me, making that Titanic look the way you want it, is not a low cost endeavor. It's not about cost, it's about finding someone to do the work. Link to comment Share on other sites More sharing options...
5Design Posted May 15, 2023 Author Share Posted May 15, 2023 1 hour ago, ericepv said: If a decent 3D symbol is available, I can help you out. No, I need someone to make the 3D symbol. Thanks, Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 15, 2023 Share Posted May 15, 2023 50 minutes ago, 5Design said: It's not about cost, it's about finding someone to do the work. They have quite a few versions of the titanic on 3dwarehouse that you can import into chief Link to comment Share on other sites More sharing options...
5Design Posted May 15, 2023 Author Share Posted May 15, 2023 2 minutes ago, Renerabbitt said: They have quite a few versions of the titanic on 3dwarehouse that you can import into chief Great, thank you. Hadn't considered that. Link to comment Share on other sites More sharing options...
Gawdzira Posted May 15, 2023 Share Posted May 15, 2023 There are also some 3D dedicated websites with job boards where you can probably find a freelancer to help with your model. I would recommend you treat this as two projects requiring different skillsets. Otherwise, you might get a mediocre version of each side of the project if you have one person do both pieces. https://forum.highend3d.com/ 1 Link to comment Share on other sites More sharing options...
