the window with the stucco look
SHCanada2
hmm, i think i pulled the wall up earlier when I had the gable roof  lower ... but the default wall heights are greyed out so it must be autogenerated??
if I redraw the 2nd floor wall, then there CA creates the upper and lower wall, but then the lower wall shows as not the default wall height, and then if I check it, it goes back to being a two story wall
any idea how to fix it?
694 Muirfield Cr - fe.zip
6 hours ago, SHCanada2 said:
any ideas why this might happen
Instead of making the lower porch two stories, return its heights to default and draw another railing room on the second floor, make the railing walls invisible and mark the room open below.
1371324742_ScreenShot2023-05-08at8_33_30AM.thumb.png.30b8af0b4f18c00a136c9e3d7cfb519a.png
Just to explain what's going on:
You placed the window on the second floor plan, but since you made the porch two stories, that wall is being driven by the first floor plan. The two-story first floor wall doesn't know the window is there. Alternatively to the above correct solution, you could place the window on the first floor then edit its vertical placement to get it where it belongs, but it won't show on the second floor plan.
598010137_ScreenShot2023-05-08at8_51_58AM.thumb.png.557c96970691a9b823fefe7173c707a0.png
1924959980_ScreenShot2023-05-08at8_54_14AM.thumb.png.58dedb1ded0546a0bbd99fc586433b45.png
