Double Door Active / Passive Leaf Display
JKEdmo
Go to solution Solved by TeaTime,
Hello,
Does Chief have an option to graphically display active / passive leaves for a double door?
Here's what I'm after below.  (Note I cobbled together 2 single leaf doors to illustrate)
Edit: I guess I should clarify that I'm looking for active leaf at 90 degrees and passive at 45 degrees -- ignore the "A" and "P"
Thanks again,
Jim
  • Solution
Naw, the Swing amount is shared across all panels on the door.
If it's absolutely necessary to show you'd have to do some sort of manual override - maybe set that door to a hidden layer and paste a CAD Block, etc.
