JKEdmo Posted May 3, 2023 Share Posted May 3, 2023 Hello, Does Chief have an option to graphically display active / passive leaves for a double door? Here's what I'm after below. (Note I cobbled together 2 single leaf doors to illustrate) Edit: I guess I should clarify that I'm looking for active leaf at 90 degrees and passive at 45 degrees -- ignore the "A" and "P" Thanks again, Jim Link to comment Share on other sites More sharing options...
Solution TeaTime Posted May 4, 2023 Solution Share Posted May 4, 2023 Naw, the Swing amount is shared across all panels on the door. If it's absolutely necessary to show you'd have to do some sort of manual override - maybe set that door to a hidden layer and paste a CAD Block, etc. Link to comment Share on other sites More sharing options...
JKEdmo Posted May 4, 2023 Author Share Posted May 4, 2023 15 minutes ago, TeaTime said: Naw, the Swing amount is shared across all panels on the door. Thanks Tea Time! Say "hi" to Kermit for me. Jim 1 Link to comment Share on other sites More sharing options...
glennw Posted May 4, 2023 Share Posted May 4, 2023 You can use your 2 doors together as you have done or mull them to form a single unit. 1 Link to comment Share on other sites More sharing options...
JKEdmo Posted May 5, 2023 Author Share Posted May 5, 2023 30 minutes ago, glennw said: You can use your 2 doors together as you have done or mull them to form a single unit. Thanks Glenn. That's really clever. Jim Link to comment Share on other sites More sharing options...
