LeRoyWells Posted April 20, 2023 Share Posted April 20, 2023 Hi I have the foundation to have a -4 offset, the back porch is working but the front porch is not. What is wrong ? Thank you I am using X15 MARY RUTH SMITH.zip Link to comment Share on other sites More sharing options...
Chrisb222 Posted April 20, 2023 Share Posted April 20, 2023 28 minutes ago, LeRoyWells said: Hi I have the foundation to have a -4 offset, the back porch is working but the front porch is not. What is wrong ? Thank you I am using X15 MARY RUTH SMITH.zip 138 B · 0 downloads Your file contains no data. You have to close Chief before zipping. Link to comment Share on other sites More sharing options...
LeRoyWells Posted April 20, 2023 Author Share Posted April 20, 2023 Hi See if this works MARY RUTH SMITH.zip Link to comment Share on other sites More sharing options...
richoffan Posted April 20, 2023 Share Posted April 20, 2023 Not sure what you are referring to. Both porches 4" slab with haunch @ foundations stepped 1.5" below floor slab. The columns, front and back are 4" back from edge of slab. What -4 are you looking for? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 21, 2023 Share Posted April 21, 2023 If you're talking about those 2 side walls, then you have 2 things going on: The wall on the left is reversed. The walls aren't aligned but they're too far apart for the automatic align tools to become available. Slide them over closet to the 4" offset and the align tool should make itself available. If you simply rebuild the foundation though you should get the offset automatically. Link to comment Share on other sites More sharing options...
