Casings Missing & Door lost Adjustments
GMcGee
Go to solution Solved by TeaTime,
Hello,
Somehow we seemed to have lost the drag handles and other options from our doors.  Casings aren't showing either.  I have everything shown.  I created a basic house in a new plan and everything works fine.  Is there a way to reset plan view settings to default?  Or does anyone know why this woudl occur?
New Plan, Working
Not working plan
Windows are also greyed out
WEST.zipGenius.  Thanks!!!!  Plan uploaded.  Still having problems with the doors and windows.  However, I am making it work.  I have a weird notch issue going on where the roof meets the wall.  Need to research that a little further...but if anyone happens to be looking in my plan, much appreciated help on that too..
  • Solution
50 minutes ago, DBCooper said:
Go to your window defaults and see if you accidently changed the vertical stacking level.  If it's not that, then you might want to post the plan.
DB wins this round - this is definitely the issue. In Windows Defaults on the Options panel the Vertical Stack should be 0, not 1.
However the problem is bigger than that though because changing the Default only fixes the doors since the Windows in this plan have been placed with the vertical stack of 1.
To fix them all in one go, select a window and use the Marquee Select Similar edit tool button and then Select All Similar, Open Object, change all their stacks to 0 and you should be good.
