GMcGee Posted April 20, 2023 Share Posted April 20, 2023 Hello, Somehow we seemed to have lost the drag handles and other options from our doors. Casings aren't showing either. I have everything shown. I created a basic house in a new plan and everything works fine. Is there a way to reset plan view settings to default? Or does anyone know why this woudl occur? Not working plan Windows are also greyed out Link to comment Share on other sites More sharing options...
DBCooper Posted April 20, 2023 Share Posted April 20, 2023 Go to your window defaults and see if you accidently changed the vertical stacking level. If it's not that, then you might want to post the plan. 1 Link to comment Share on other sites More sharing options...
GMcGee Posted April 20, 2023 Author Share Posted April 20, 2023 Thanks, I will check that. any suggestions on how to downsize the plansize? I cant get it under the 14mb limit on a posting. Link to comment Share on other sites More sharing options...
someguy Posted April 20, 2023 Share Posted April 20, 2023 6 minutes ago, GMcGee said: Thanks, I will check that. any suggestions on how to downsize the plansize? I cant get it under the 14mb limit on a posting. zip file Link to comment Share on other sites More sharing options...
GMcGee Posted April 20, 2023 Author Share Posted April 20, 2023 WEST.zipGenius. Thanks!!!! Plan uploaded. Still having problems with the doors and windows. However, I am making it work. I have a weird notch issue going on where the roof meets the wall. Need to research that a little further...but if anyone happens to be looking in my plan, much appreciated help on that too.. Link to comment Share on other sites More sharing options...
Solution TeaTime Posted April 20, 2023 Solution Share Posted April 20, 2023 50 minutes ago, DBCooper said: Go to your window defaults and see if you accidently changed the vertical stacking level. If it's not that, then you might want to post the plan. DB wins this round - this is definitely the issue. In Windows Defaults on the Options panel the Vertical Stack should be 0, not 1. However the problem is bigger than that though because changing the Default only fixes the doors since the Windows in this plan have been placed with the vertical stack of 1. To fix them all in one go, select a window and use the Marquee Select Similar edit tool button and then Select All Similar, Open Object, change all their stacks to 0 and you should be good. 1 Link to comment Share on other sites More sharing options...
GMcGee Posted April 20, 2023 Author Share Posted April 20, 2023 Holy smokes, thanks. Soo much better! Now, time to go fix some dims. This forum is great! Link to comment Share on other sites More sharing options...
