AdkKen
In Terrain Specifications >  General turn off " Hide Terrain Intersected by Building".   Then let us know what version you are using as you will need to delete the "grass" from the basement afterwards.
Select your Terrain and look for a tool in your Edit toolbar called Make Terrain Hole(s) around Building(s).  When you click that tool, it will automatically toggle the Hide Terrain Intersected by Building setting and simultaneously generate one or more polyline Terrain Holes to replace the automatic version(s).  Once created just adjust or delete the unwanted hole(s) as necessary.
Once you go this route though, just remember that you'll have to manually make changes to the holes along with any changes to the plan.
