Flooring Pattern Gap at Door Opening
JKEdmo
In plan, I set the Room Specification / Fill Style option to show an existing diagonal tile pattern in a master bathroom:
The pattern fills the defined rooms perfectly, but not into the door opening.  Is there a workaround for this?
Thanks again,
Jim
Thanks again,
Jim
Workaround is to create a room polyline and fill the polyline instead of the room.  Best to put on separate locked layer when done.
Thank you Ryan for your advice.
Jim
