simonas Posted February 8, 2015 Share Posted February 8, 2015 Hey pros, Can someone help me to figure out how to create this kind of window in my basement plan? It's two separate windows they have same opened space, but are separated with this wall in the middle. Is it possible to do this in Chief? Link to comment Share on other sites More sharing options...
evergreen Posted February 8, 2015 Share Posted February 8, 2015 Do you mean something like this? Link to comment Share on other sites More sharing options...
glennw Posted February 8, 2015 Share Posted February 8, 2015 Simonas, I can't tell from your sketch what you want. Is it one window above another? Link to comment Share on other sites More sharing options...
simonas Posted February 8, 2015 Author Share Posted February 8, 2015 The photo has flipped after importing it here, sorry. Its two windows they share one gap in the "fat wall" and they have this thiner wall in the middle between them. Link to comment Share on other sites More sharing options...
glennw Posted February 8, 2015 Share Posted February 8, 2015 Ah, use a thinner wall type between the windows? Link to comment Share on other sites More sharing options...
simonas Posted February 8, 2015 Author Share Posted February 8, 2015 Have tried, but then you can not move windows close enough to that thinner wall... in my case I have gap of 200mm on each side Link to comment Share on other sites More sharing options...
glennw Posted February 8, 2015 Share Posted February 8, 2015 Simonas, Do you mean something like this> Link to comment Share on other sites More sharing options...
simonas Posted February 8, 2015 Author Share Posted February 8, 2015 Simonas, Do you mean something like this> Yes, how do you bump them to that thiner wall? Link to comment Share on other sites More sharing options...
glennw Posted February 8, 2015 Share Posted February 8, 2015 Drag them and then drag them a bit more - drag by the centre handle, not the end handle. Make sure you drag them along the main timber frame layer. Link to comment Share on other sites More sharing options...
simonas Posted February 8, 2015 Author Share Posted February 8, 2015 It looks ok in the plan view but you still have these small walls in the 3d. I guess it is not possible to accomplish it in Chief. Link to comment Share on other sites More sharing options...
joey_martin Posted February 8, 2015 Share Posted February 8, 2015 Block them together...or MULL them, and make sure SINGLE WALL HOLE is checked. That should do it. You may have to manipulate the casing/moldings, but it should model correctly. Link to comment Share on other sites More sharing options...
joey_martin Posted February 8, 2015 Share Posted February 8, 2015 Nevermind....won't work for that. Link to comment Share on other sites More sharing options...
