Door Placement
JKEdmo
Go to solution Solved by DBCooper,
Regarding door placement tool:
Does Chief have any hotkeys that toggle the door orientation during placement?  For example, toggle between inswing / outswing and left / right?
Thanks,
Jim
  On 3/7/2023 at 7:20 PM, DBCooper said:
You can place a door into any of the 4 door orientations.
Expand
OK, I see inswing and outswing is controllable (I knew that already and spaced out!).
But is there a way to reverse the door swing direction on the fly before placement?  If there is, I don't know the technique.
Thanks,
Jim
During placement you can just drag to change the Swing Side.  Otherwise, after placement you can use the Edit Tools to change the Hinge Side and Swing Side - or use C,H and C,S hotkeys to do the same.  I find the hotkeys to be slower and not as consistent.
I don't know of any way to change the Hinge Side during placement.
