JKEdmo Posted March 7, 2023 Share Posted March 7, 2023 Regarding door placement tool: Does Chief have any hotkeys that toggle the door orientation during placement? For example, toggle between inswing / outswing and left / right? Thanks, Jim Link to comment Share on other sites More sharing options...
DBCooper Posted March 7, 2023 Share Posted March 7, 2023 Click and drag until it is how you want it. You can place a door into any of the 4 door orientations. Link to comment Share on other sites More sharing options...
JKEdmo Posted March 7, 2023 Author Share Posted March 7, 2023 1 hour ago, DBCooper said: You can place a door into any of the 4 door orientations. OK, I see inswing and outswing is controllable (I knew that already and spaced out!). But is there a way to reverse the door swing direction on the fly before placement? If there is, I don't know the technique. Thanks, Jim Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 7, 2023 Share Posted March 7, 2023 During placement you can just drag to change the Swing Side. Otherwise, after placement you can use the Edit Tools to change the Hinge Side and Swing Side - or use C,H and C,S hotkeys to do the same. I find the hotkeys to be slower and not as consistent. I don't know of any way to change the Hinge Side during placement. 1 Link to comment Share on other sites More sharing options...
Solution DBCooper Posted March 7, 2023 Solution Share Posted March 7, 2023 Left click and hold the button down, drag the mouse around, and then let the button up. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 7, 2023 Share Posted March 7, 2023 6 minutes ago, DBCooper said: Left click and hold the button down, drag the mouse around, and then let the button up. Thanks DB Link to comment Share on other sites More sharing options...
JKEdmo Posted March 7, 2023 Author Share Posted March 7, 2023 19 minutes ago, DBCooper said: Left click and hold the button down, drag the mouse around, and then let the button up. Thanks! That's what I was looking for. Very good tip. Jim Link to comment Share on other sites More sharing options...
