ACAaron Posted March 3, 2023 Share Posted March 3, 2023 90% of my Library Symbols are either custom, or ones I found in Chief library that I moved to my user Catalog. I'd like to be able to search for something, but limit the search to just my User Catalog. I am not able to find a way to create a filter for this. Any suggestions on searching in my own User Library easier? Link to comment Share on other sites More sharing options...
glennw Posted March 3, 2023 Share Posted March 3, 2023 For X13. Have you tried Manage Library Filters? Link to comment Share on other sites More sharing options...
MarkMc Posted March 3, 2023 Share Posted March 3, 2023 Once a new filter is saved.... Link to comment Share on other sites More sharing options...
ACAaron Posted March 14, 2023 Author Share Posted March 14, 2023 Odd. For some reason, I don't get the option for "User" in the Filter. I do see I can right click on my User Catalog and do a search; however, I'd prefer to create a filer. Any suggestions? Link to comment Share on other sites More sharing options...
MarkMc Posted March 14, 2023 Share Posted March 14, 2023 14 minutes ago, ACAaron said: Any suggestions? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 14, 2023 Share Posted March 14, 2023 If you're still in X14, just right click on the User Library and select Search Folder. If you're on X15, just click on the User Library and then enter your search term(s). No need to even set up a special filter. Link to comment Share on other sites More sharing options...
MarkMc Posted March 15, 2023 Share Posted March 15, 2023 11 hours ago, Alaskan_Son said: No need to even set up a special filter. There is a difference if you work primarily from the User Catalog as the OP does, and I do. When accessing the library from a DBX in X14 and you have a saved filter in use that filter applied. Image below the User Filter was on prior to opening DBX There is a down side to that if you don't know how the filters work -if the object currently listed in the DBX is not found with the filter on you won't see it. I suppose this could be a problem for some newbies? X15- the saved filter is dropped completely in favor of what the program has decided for you, your saved filters are not accessible in that DBX all of which leaves you to rummage around or use the start clicking your way in the search. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 15, 2023 Share Posted March 15, 2023 5 hours ago, MarkMc said: There is a difference if you work primarily from the User Catalog as the OP does, and I do. When accessing the library from a DBX in X14 and you have a saved filter in use that filter applied. Image below the User Filter was on prior to opening DBX There is a down side to that if you don't know how the filters work -if the object currently listed in the DBX is not found with the filter on you won't see it. I suppose this could be a problem for some newbies? X15- the saved filter is dropped completely in favor of what the program has decided for you, your saved filters are not accessible in that DBX all of which leaves you to rummage around or use the start clicking your way in the search. You're kind of moving the goalpost here. Until now there was no discussion about using the Library in Select Library Object mode. I was only responding to the original question. Link to comment Share on other sites More sharing options...
