SHCanada2 Posted February 28, 2023 Share Posted February 28, 2023 I thought maybe construction lines would work, but they do not show up if they are at an angle on plan view. I see some other options, 1. really short construction lines at building corners, 2. put a really skinny post at the property corners which is also really tall draw a line on the elevation but then one cannot see if it is matching plan view. I suppose one could dimension it on elevation, as a sanity check, but the dimension snaps to outside of building not framing. Anyone have better ideas? construction lines would be nicer in this instance if they had labels in the middle of the line, below the line below are construction line Link to comment Share on other sites More sharing options...
javatom Posted February 28, 2023 Share Posted February 28, 2023 You could draw a solid fence where the property line is located. Make that layer show up in the layers for elevation. Link to comment Share on other sites More sharing options...
scottharris Posted February 28, 2023 Share Posted February 28, 2023 A couple of options: 1. Use the construction line; in your elevation view, match the angle of the line 2. Use a thin polyline solid for the property line if your elevation needs to be straight on 1 Link to comment Share on other sites More sharing options...
SHCanada2 Posted February 28, 2023 Author Share Posted February 28, 2023 1 hour ago, scottharris said: . Use the construction line; in your elevation view, match the angle of the line hmmm, then i would need two elevations for each of front and back for pie lots for 2, for a pie lot, then front elevation would then show a thick psolid: 1 hour ago, javatom said: You could draw a solid fence where the property line is located. Make that layer show up in the layers for elevation. I think that would be same as above... a 1"x1" by 600" high psolid works...but a little cumbersome to dimension to (center vs edge) I think the little construction line is easiest at the four corners. And I can turn off the callout in plan view but leave it in elevation. only problem is if i change the outside walls of the house to be nearer the PL, by extending the house, I have to move the construction line 1x1 psolid on the left, little construction line on the terrain perimeter below Link to comment Share on other sites More sharing options...
