problem with wall connecting to the ceiling
GP202256
If all you want to do is close that gap and you don't care about the ceiling height being correct, you can open up that wall and select Balloon Through Ceiling in the structure tab.
If you want the lower slope of the ceiling planes to match your room ceiling height, open up your ceiling planes and select radio button to lock pitch at 6, then enter 109 1/8" for the Bottom Height of ceiling planes.
Then you probably want to open up each of your trusses and select the radio button for Force Truss Rebuild if you want your trusses to have a flat seat to sit on the wall.
42 minutes ago, GP202256 said:
I did everything and thanks, the only thing that did not happen was the flat seat at the truss bottom after rebuild.
Okay good, hopefully that gets you close enough for what you need. The flat truss seat thing could be because of X15, truss framing in general seems to work better so far in X15.
