AriseDesign Posted February 5, 2015 Share Posted February 5, 2015 Please don't tell me that a rotated 3D Block Chief will not update its 2d view on plan? Link to comment Share on other sites More sharing options...
rlackore Posted February 5, 2015 Share Posted February 5, 2015 The 2D block (plan view) of a symbol should rotate along with the symbol. Can you elaborate or post a plan of the problem? Link to comment Share on other sites More sharing options...
AriseDesign Posted February 5, 2015 Author Share Posted February 5, 2015 see attached - I created a shutter in Autocad, brought it in as a 3d block when I rotate it to be wall mount the floor plan view does not update shutter.zipFetching info... Link to comment Share on other sites More sharing options...
ArthurDent Posted February 5, 2015 Share Posted February 5, 2015 The cad blocks won't update automagically if you rotate the 3D data in the open symbol dialog. You need to create your own block or use the "generate block" button. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 5, 2015 Share Posted February 5, 2015 You have to create your own 2d block and associate it to the symbol. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 5, 2015 Share Posted February 5, 2015 Arthur's answer is the best. Open the Symbol in your Library and Generate 2D Block. Then it will be correct when inserted into a Plan. Link to comment Share on other sites More sharing options...
