HumbleChief Posted January 30, 2023 Share Posted January 30, 2023 Can't figure out what's happening with the pony wall display. User error most likely but any help appreciated. https://www.dropbox.com/s/m9z7mzvjkaxnj23/PONY WALL DISPLAY.plan?dl=0 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 30, 2023 Share Posted January 30, 2023 Haven't explored WHY its happening, but what you're seeing is your Slab Footing Wall from your foundation level extending up from below. Link to comment Share on other sites More sharing options...
HumbleChief Posted January 30, 2023 Author Share Posted January 30, 2023 On 1/30/2023 at 7:06 PM, Alaskan_Son said: Haven't explored WHY its happening, but what you're seeing is your Slab Footing Wall from your foundation level extending up from below. Expand Thanks Michael. Yes, that's what's happening but can't seem to figure out the why or a fix. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 30, 2023 Share Posted January 30, 2023 are all the walls aligned with the foundation? Link to comment Share on other sites More sharing options...
HumbleChief Posted January 30, 2023 Author Share Posted January 30, 2023 On 1/30/2023 at 7:14 PM, DRAWZILLA said: are all the walls aligned with the foundation? Expand Hey P, the foundation is on auto build so that should align the walls, no? Link to comment Share on other sites More sharing options...
HumbleChief Posted January 30, 2023 Author Share Posted January 30, 2023 Seems to work OK on my template plan so.... Link to comment Share on other sites More sharing options...
HumbleChief Posted January 30, 2023 Author Share Posted January 30, 2023 Kinda sorta have it figured out. When I build the foundation I have the 'curb width' set to 8" but when the foundation is built Chief sets that curb width to 16". I can manually change the curb width on each foundation wall back to the intended 8" and the problem goes away. 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted February 6, 2023 Author Share Posted February 6, 2023 Sent the problem to tech support and they were able to duplicate the problems with no current fix. Two things. The foundation curb width only builds to footing width no matter the 'Slab Footing Defaults' setting. Second, the footing builds to the roof depending on which surface or layer the pony wall is located. Referred to the development team. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 6, 2023 Share Posted February 6, 2023 On 2/6/2023 at 4:10 PM, HumbleChief said: Sent the problem to tech support and they were able to duplicate the problems with no current fix. Expand Try setting your Default Slab Footing to a Pony Wall using a Room Divider as its main wall type. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 6, 2023 Author Share Posted February 6, 2023 On 2/6/2023 at 5:16 PM, Alaskan_Son said: Try setting your Default Slab Footing to a Pony Wall using a Room Divider as its main wall type. Expand Thanks Michael but that's a bit over my pay scale. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 6, 2023 Share Posted February 6, 2023 On 2/6/2023 at 5:53 PM, HumbleChief said: Thanks Michael but that's a bit over my pay scale. Expand Build Foundation>Edit Default Slab Footing OR Default Settings>Walls>Slab Footing and then click on the Wall Types tab, check Pony Wall, and set the upper wall to Room Divider. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 6, 2023 Author Share Posted February 6, 2023 Thank you again Michael but I'm moving on and will wait and see how X15 treats this condition. Thanks again. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 22, 2023 Author Share Posted February 22, 2023 Looks like X15 addresses and fixed this issue. Link to comment Share on other sites More sharing options...
