rhadkins2002 Posted January 29, 2023 Share Posted January 29, 2023 I'm returning to Chief Architect after being away for years and have forgotten where to put CALIBZ files. Would someone, please, point me in the correct direction? Thanks, Rick https://i.gyazo.com/8a2aa5f3d3a6737edfd8facdf89fdf95.png Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 29, 2023 Share Posted January 29, 2023 Import into your user Library. 1 Link to comment Share on other sites More sharing options...
JKEdmo Posted January 29, 2023 Share Posted January 29, 2023 Rick, When I download a new library file from Chief, I just double click the file and it self-installs. Jim 1 Link to comment Share on other sites More sharing options...
rhadkins2002 Posted January 29, 2023 Author Share Posted January 29, 2023 I'll try that. Sounds familiar. Do I delete the file once it's done installing? Link to comment Share on other sites More sharing options...
JKEdmo Posted January 29, 2023 Share Posted January 29, 2023 You probably could. I'm on a PC, and the file just winds up in my "downloads" folder, which I empty from time to time. Here's more info on the process: https://www.chiefarchitect.com/support/article/KB-00090/obtaining-library-content.html Jim Link to comment Share on other sites More sharing options...
Kbird1 Posted January 29, 2023 Share Posted January 29, 2023 16 hours ago, rhadkins2002 said: I'll try that. Sounds familiar. Do I delete the file once it's done installing? You Can save them for Future Use on an External Drive too if worried about space Chief now has over 430 Downloads available.....1 by 1 If Chief is Open and aNew Plan is Open , you can Click Open File once downloaded in Edge and they will install into X14 ( as long as .calibz Files are associated with X14. see Preferences if it doesn't work , there is a big button to click.) I haven't update this since Sept but the PDF will give to a List to start with....... 1 Link to comment Share on other sites More sharing options...
JKEdmo Posted January 29, 2023 Share Posted January 29, 2023 1 hour ago, Kbird1 said: You Can save them for Future Use That's probably the best habit. Along these lines, do you happen to know if Chief ever "retires" libraries or are they more or less always available on their website? Jim Link to comment Share on other sites More sharing options...
Kbird1 Posted January 29, 2023 Share Posted January 29, 2023 13 hours ago, JKEdmo said: That's probably the best habit. Along these lines, do you happen to know if Chief ever "retires" libraries or are they more or less always available on their website? Jim In the Sort Term no but yes Chief has a Policy to only support the previous 8 Versions, so currently Libraries as far back as x7 are available, however as far as I know only the current Versions Files are ever updated/fixed. If you have the X12 version of a Library you can install it and Run the Catalog up Date ( good habit to do once a week or so anyway ) and it will be updated to the current X14 version for example , so saved downloads can work to advantage that way too ie save a redownload , one trick is if a Library is updated auto. but is now missing something you like or used a loot is to re-name the older version /calibz file and re-install it the normal way. The renaming seems to stop the "Updater" from recognizing older Libraries and leaves them alone. * I found this out by accident as some of Chief's naming schemes aren't all that intuitive, and added info to file name I was saving. M. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 29, 2023 Share Posted January 29, 2023 Just a FYI , I redid my List and it seems we now have 461 Libraries. Here is the PDF........................Chief Libraries Jan. 29th-2023.pdf Mick. Link to comment Share on other sites More sharing options...
JKEdmo Posted January 29, 2023 Share Posted January 29, 2023 Thanks Mick, very helpful. Jim Link to comment Share on other sites More sharing options...
