DeLayDesign Posted January 21, 2023 Share Posted January 21, 2023 It's not very often I come across them, but from time to time they pop up. I can remember figuring out how to make it work for me before, but now I can't see to remember. I know I can build it in sections with invisible walls, and place the columns myself, but what's the proper way to get chief to realize the first floor wall shouldn't travel past the second? Link to comment Share on other sites More sharing options...
DeLayDesign Posted January 21, 2023 Author Share Posted January 21, 2023 OK; so what I ended up doing was pulling the first floor wall down manually, then grabbed the second floor wall from the side (the top wouldn't let me pull it down) and pulled it all the way across the front face. Bizzar ar. Link to comment Share on other sites More sharing options...
SNestor Posted January 21, 2023 Share Posted January 21, 2023 There are probably other ways to create this design...see the attached screen clip. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted January 22, 2023 Share Posted January 22, 2023 On 1/21/2023 at 10:49 AM, DeLayDesign said: I know I can build it in sections with invisible walls, and place the columns myself, but what's the proper way to get chief to realize the first floor wall shouldn't travel past the second? I'm not sure there is a "proper way" , I think it's another of Chief's Quirks , ie the 1st floor wall ignoring the 2nd floor wall that is already above it in this situation, it should "sense" the wall / floor platform above and stop UNLESS the user Balloons it Up. ( The 1st floor Wall doesn't sense 2nd Floor Windows either which is a problem I run into occasionally and if that happened this Issue would come up either.) * Like you I had to pull the 1st floor wall back down manually ( unfortunately there's no "stop at 2nd Floor platform" radio button. Plan File incase some future Reader would like it...............Forum 2 Storey Front Porch.plan Mick. 1 Link to comment Share on other sites More sharing options...
