sthieldesign Posted January 17, 2023 Share Posted January 17, 2023 My ceiling molding is not wrapping a soffit all the way. I am creating a shower. When I put a glass wall at the doorway, no molding appears. When I place a pony wall the same thing. How can I get the molding to wrap the soffit all the way? Thank you! Susan Link to comment Share on other sites More sharing options...
sthieldesign Posted January 17, 2023 Author Share Posted January 17, 2023 I was trying to avoid that, does not always line up correctly. I guess that is the only way? Thank you Susan Link to comment Share on other sites More sharing options...
Chrisb222 Posted January 17, 2023 Share Posted January 17, 2023 34 minutes ago, sthieldesign said: I was trying to avoid that, does not always line up correctly. You can convert the existing molding to a molding polyline, then extend it around the missing spaces of the room and it will line up. Link to comment Share on other sites More sharing options...
DBCooper Posted January 17, 2023 Share Posted January 17, 2023 This may all depend on how you created the molding. If your crown molding is done through the room dialog, you may have a wall that is marked as not having a molding. You may also have a room divider or other wall and you may have one room without the crown molding. If your crown molding is done through a cabinet soffit, a soffit can span multiple rooms and the moldings can get messed up when this happens. I have sometimes used a countertop instead of a soffit to solve problems like this. As Chris pointed out, you can also convert a room molding into a molding polyline and then modify the shape or turn on/off the molding on any edges you need to. It would be nice if we could also do this for cabinet/soffit/counter moldings. Link to comment Share on other sites More sharing options...
