Extra lines in fascia
bdammeyer
I assume that you added that return manually, when you place a return via the Wall Specification Dialog box you get no extra lines usually. Sometimes that setting does not work and a manual return is then necessary. Such lines are EASILY handled after the view is sent to layout, while on layout any missing or unwanted lines can be added or removed easily using while on layout the "Edit Layout Line" tool available in your edit tool bar when you select a view you wish to edit.
1 hour ago, bdammeyer said:
Hello,
Anybody know a way to avoid having these extra lines in the fascia of a roof return?
Did you join it with the Join Tool properly? , you will get extra lines too if there is even the slightest mis-alignment of two surfaces
