Roof Over Entry Door
BrentJohnJohn
Greetings,
It has been awhile since my last post.
I have reviewed the Forum for more than an hour and not able to find any suggestions to my problem. Per the attached, I am needing to create a "roof" over the front entrance area. I have tried several different ways, and no success.
Forney 01_09_23.pdfFetching info... Forney 01_09_23 Sample.planFetching info...
If you're wanting to just have your roof cover the existing area, you may want to look at the Minimum Alcove size setting at the bottom of the build roof dialog. I set it to 6' and turned auto rebuild roof back on I came up with something like this:
  • Upvote 2
If you're looking for a Gable/Hip/Gable type scenario, the patio (invisible) wall need to be pulled back slightly so that it lines up with the main layer of the brick garage wall
then, if the two gable walls are marked as Gable (under the wall spec Roof panel), when you Build Roof, the roof should build over that space normally.
Though I see that Auto Roofs is not on, and other roofs change when telling chief to Build Roof, so there may be some tweaking needed after the fact.
