Remove backdrop on floor plan and elevations
Brittany110
3 minutes ago, Brittany110 said:
I added a gray backdrop to my floor plan and elevations and now when I send it to the layout as a image it as the gray backdrop. how do I remove the backdrop in the floor plan mode so it doesn't send over to the layout with a gray background ?
You are not using Chief's send to layout by its intended and designed use. Is there a reason you are sending as an image? Simple solution is send as something other than an image, which would be preferred.
Also consider putting your specs schedule in a CAD detail and send to layout
  • Upvote 2
Our cabinet install drawings are done in cabinet vision software. so I imported an image of cabinet vision drawings to CA . when I send it to the layout im doing it as a image. ill look into the CAD detail. I'm new to CA so still trying to figure it out! thanks much :)
