Scalloped Windows
katemileti
Mick thanks glad if that helped.
1 draw a roof with facia and ridge the same height(roof horizontal no slope)
2 draw a cad polyline that has the shape and dimensions of your window
3 copy holding C inward to set the frame
4 click the curved parts and change to around 32 segments( actually it depends) the main thing is to get smooth curve.
5 the next step is subtracting cad plines from the roof to get sky lights and set frame width the minimum value.
6 change to symbol.......
  On 2/1/2015 at 10:24 PM, Kbird1 said:
After seeing your Spiral Staircases I should have known this was pretty simple for you :)  .......once again nice thinking outside the Box.
I will need to try this , should be a good Chief Lesson
Mick
Mick
Thank you very much.
