GeneDavis Posted October 4, 2022 Share Posted October 4, 2022 I use Sketchup 2017, the free one, and have no access to most all of the 3D Warehouse. If you've access and are willing, will you please get and post these three Weber grilles? Weber Summit Gas Grille BBQ Grille Weber Genesis Simple Charcoal Grille I used the exact title of each so search should bring them up. Thanks. Link to comment Share on other sites More sharing options...
robdyck Posted October 4, 2022 Share Posted October 4, 2022 https://3dwarehouse.sketchup.com/search/?q=Weber Summit Gas Grille&searchTab=model Link to comment Share on other sites More sharing options...
robdyck Posted October 4, 2022 Share Posted October 4, 2022 On 10/4/2022 at 1:23 PM, GeneDavis said: have no access to most all of the 3D Warehouse. Expand Are you sure about that? Does the link I posted work for you? Link to comment Share on other sites More sharing options...
GeneDavis Posted October 4, 2022 Author Share Posted October 4, 2022 A year ago or more, Google changed the 3D Warehouse access to be subscription only. Before that, my Sketchup Make 2017 Free could download anything up at the Warehouse. It is greatly limited now. They disabled the Warehouse access that is in the SU 2017. A subscription is quite a bit more annually than SSA. So until they figure out how to disable my on-board SU 2017, I'm not going there just to be able to access the warehouse. From the Components panel, I can browse it, but is not a rich a search as going to the main site. And while a very few items can import, most cannot. Why some very few models can import, and not others, is a mystery. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 4, 2022 Share Posted October 4, 2022 Hi Gene, I don't have a subscription and just use https://3dwarehouse.sketchup.com/ Am I missing something? Link to comment Share on other sites More sharing options...
GeneDavis Posted October 4, 2022 Author Share Posted October 4, 2022 I can bring into Chief anything that has a Collada (.dae) format, which is a lot, but I cannot edit the model like I can if I can bring it into my SU app. So for example, one of the Weber grilles I brought into Chief has a 2D image of a man in it and I don't know how to edit him out. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 4, 2022 Share Posted October 4, 2022 Ahhh, I see the problem. There are some symbols that need to be broken down to their component pieces. I just avoid using those. I guess it requires the "Pro" subscription to have those capabilities in Sketchup. I suppose in Chief you could delete the surfaces and then create a symbol of what's left. That's not always very easy. Link to comment Share on other sites More sharing options...
GeneDavis Posted October 4, 2022 Author Share Posted October 4, 2022 I tried that and no work-y. Link to comment Share on other sites More sharing options...
designsbyday Posted October 4, 2022 Share Posted October 4, 2022 I would check w/David at Cheif tutor. He has made such symbols for me before. 1 Link to comment Share on other sites More sharing options...
DMDesigns2 Posted October 4, 2022 Share Posted October 4, 2022 Sure thing - Just follow this link: https://www.chieftutor.net/free-symbols-give-away.html Link to comment Share on other sites More sharing options...
robdyck Posted October 7, 2022 Share Posted October 7, 2022 On 10/4/2022 at 3:51 PM, GeneDavis said: but I cannot edit the model like I can if I can bring it into my SU app. Expand Why don't you just use the free SketchUp app online? I use it to edit symbols for the same reason you mentioned...I only have SketchUp 2017. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 7, 2022 Share Posted October 7, 2022 3D Warehouse removed models older than 2018 last July ....at least that's what was announce last year , and as Rob mentioned youow need to use the Web-Base App for free access. https://chieftalk.chiefarchitect.com/topic/31473-sketchup-3d-warehouse-is-dumping-models-older-than-2018-versions-on-july-27th/?tab=comments#comment-251409 M. Link to comment Share on other sites More sharing options...
