Material Eye Dropper function
buzzsaw204
Go to solution Solved by DBCooper,
Pattern lines on wall don't always change with certain adjustments. To get the wall to refresh, simply double click the wall then close the dialog without changing anything.
F12 forces a model rebuild however pattern lines don't always rebuild correctly for all object when using F12. Sometimes you need to 'open' and then 'close the object to get pattern lines to update.
