ChiefuserMathews Posted September 2, 2022 Share Posted September 2, 2022 when I use the auto elevation dimension, I get 2 sets of dimension as shown in the image. Where is the settings to remove the inner dimension? Link to comment Share on other sites More sharing options...
robdyck Posted September 2, 2022 Share Posted September 2, 2022 Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted September 2, 2022 Author Share Posted September 2, 2022 No that is not the one. That applies to auto story pole dimension. I am doing the auto elevation dimension Link to comment Share on other sites More sharing options...
DG1949 Posted September 2, 2022 Share Posted September 2, 2022 My auto elevation dimensions don't seem to respond to any directive in the default settings dialog. Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted September 2, 2022 Author Share Posted September 2, 2022 On 9/2/2022 at 12:41 PM, robdyck said: Expand Robert, mine is unchecked (screen shot attached) but still it gives 2 sets of dimensions Link to comment Share on other sites More sharing options...
robdyck Posted September 2, 2022 Share Posted September 2, 2022 All I can suggest is to make sure you are editing the correct dimension default set used in that view (you can access that by double-clicking that particular dimension), and then to remove all the locate checkmarks from the Outer Dim. column. Otherwise, a plan file would be needed. Link to comment Share on other sites More sharing options...
Solution robdyck Posted September 2, 2022 Solution Share Posted September 2, 2022 Uncheck Overall Dimension 1 1 Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted September 2, 2022 Author Share Posted September 2, 2022 On 9/2/2022 at 1:18 PM, robdyck said: Uncheck Overall Dimension Expand Thanks Robert. That worked. Have a great day 1 Link to comment Share on other sites More sharing options...
robdyck Posted September 2, 2022 Share Posted September 2, 2022 You're welcome Wilson! If you don't mind checking 'solved' in the upper right corner of the correct post, it helps other forum readers! Link to comment Share on other sites More sharing options...
DG1949 Posted September 2, 2022 Share Posted September 2, 2022 On 9/2/2022 at 1:18 PM, robdyck said: Uncheck Overall Dimension Expand That works! Thank you! 1 Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted September 2, 2022 Author Share Posted September 2, 2022 Thanks Robert. Please check if I did it right as solved. I didn't see on the top right 1 Link to comment Share on other sites More sharing options...
robdyck Posted September 2, 2022 Share Posted September 2, 2022 Yup, you got it. Link to comment Share on other sites More sharing options...
