gelbuilding Posted August 30, 2022 Share Posted August 30, 2022 Small problem with a model. The job has demo walls which have been drawn on a demo layer set. All works well though when i change to new layout layer set you can see where the demo walls are located as it cuts through the tiles floor finish. Dont know how to fix this. Link to comment Share on other sites More sharing options...
Solution glennw Posted August 30, 2022 Solution Share Posted August 30, 2022 Try making the walls invisible instead of turning the wall layer off. Normal walls cut through a floors Finish Layers so turning off the display layer the walls are on still leaves the floor finish cutouts. Invisible walls do not make the cutout in the floor finish layers. 1 Link to comment Share on other sites More sharing options...
gelbuilding Posted August 30, 2022 Author Share Posted August 30, 2022 Thanks Glenn Link to comment Share on other sites More sharing options...
Kbird1 Posted August 30, 2022 Share Posted August 30, 2022 12 hours ago, gelbuilding said: The job has demo walls which have been drawn on a demo layer set. Look into using Reference Displays ( dedicated Demo Layerset in orange with XOR on below) for your Demo Display and use a dedicated Plan View for Demo Conditions perhaps , it works well.... 2 Link to comment Share on other sites More sharing options...
gelbuilding Posted September 2, 2022 Author Share Posted September 2, 2022 Hi Mick Nice one, i like it. Thanks Link to comment Share on other sites More sharing options...
