Soffit Under Ceiling
HarrisReno
2 hours ago, HarrisReno said:
And I really appreciate the lighting tip!
Another would be in the Standard view to set both Ambient Lighting sliders to 55-60% , I have it set in my template now so I don't need to do it every time, (along with the Ambient Occlusion Eric mentioned set to 20%), I am not sure why chief sets it at 31% as it always seems "dull" to me.... , maybe personal preference too?
After you use the "place under ceiling", you might want to lower the soffit by 3/4" otherwise it will be embedded in your ceiling which will cause missing lines.  I think this only happens when you are using custom ceilings like this.
You might also want to fix up the side soffit too since it is embedded into the wall.
I like to do all of my modelling in vector views so that it is easier to see these kinds of problems.
In X14 , I have started using STD View with Lines , but that may depend on the Computer/GPU as it is likely "harder" resources wise.
Mick.
