How To Create an Opening Between Two Staggered Platforms
DRyeHD
O wise ones,
I need some input regarding how to get an open space between two "staggered" floors (for lack of a better description).  The front area (loft) has an 11 foot ceiling.  The mid-to-back area (bedroom and bath) has a 7 1/2 foot ceiling.  Between the two areas is open all the way to the A-frame ceiling and a short stair for access between the two platforms.
When I try to use a hole in ceiling platform, I get an unwanted material along the bedroom rail and it just doesn't seem to work right (see attached picture).  Am I taking the wrong aproach using the hole in platform?  Do I need to redefine the Dining and Entry rooms below to make it work better?  Any input would be appreciated.
I've attached the .pln file.
Strickland.zip
David,
Sorry for the slow response.  Between the weekend and other work this morning, I'm just now getting back.  I was able to watch your full video.  It was helpful.  I had never used the "no material" option.  That took care of most of my ceiling issue.
Actually, the stairs are shown in the attached picture.  I threw those in because my customer wants to do away with the existing spiral stairs and put in a straight or u-shaped stair.  I've come up with a couple of options.  My main issue was getting the open ceiling between the staggered floors.
Thanks again for taking time to do the video.  A picture is worth 1000 words, but a video is worth a million!
Have a great day,
Damon Rye
Eric,
Thanks for taking time to make the video.  I'm just back on this project today and have corrected my design with your recommendation.   I was trying to use the "draw it like you build it" technique, but your method (and @Alaskan_Son's suggestion) seem to work the best.  Again, thanks for the input.
