Member Statistics
Similar Content
By kathleenjennison
I'm working on a lobby space and the first floor will only show the curved stairs. I can't seem to get the landing and stairs from the second floor to show on the first floor.
Any one know how to get the landing and stairs to show?
By DRyeHD
I can't find answers to three challenges I'm having with this stairway. On the lower section, I need an open stairway with one stringer - treads stopping 2" away from outside wall. The landings need to be open (like the lower section). Then I need the top section to be closed.
Is there a way to modify the lower and upper sections seperately? How do I get the landings to be open underneath?
As always, your input is appreciated!
By Designer100
Can anyone help. finish floor is 36 in above grade . Stairs are staying at grade level! Chief support has not gotten back with me in over 2 days.
Second issue- window shutters will not change colors to look like door?
Chief Architect 14
Misael Gomez Residence.zip
By Thewoodmaster
I cant for the life of me get the two inside mitered 45 corners to connect the stairs together, or get the small section by the wall to even draw the stairs. I also cant get the direction of the grain on the deck boards to run the right way. I tried copy the material and rotate it, but no luck. The stairs are just pissing me off at this point. Also why are the treads showing up as a single tread and not 2 deck boards.
patio plan.plan
