Tony-209 Posted June 2, 2022 Share Posted June 2, 2022 Hi Guys, Kind of new to the software, however, I have designed a house for a customer, and they recently changed the ceiling heights from 8' to 9', whilst I did this using the Rooms setting, the roof line hasn't changed, and I an not sure how to do this without redrawing the exterior walls again? Link to comment Share on other sites More sharing options...
Tony-209 Posted June 2, 2022 Author Share Posted June 2, 2022 No sure what you mean, I have raised the ceiling to 9' and yes I cannot use Auto Rebuild because I have some manual roofs I don't want to rebuild, any chance you can show me Eric? Link to comment Share on other sites More sharing options...
rwdozier Posted June 2, 2022 Share Posted June 2, 2022 Couldn't you Build Roof Planes and Retain Manually Drawn Roof Planes? 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted June 2, 2022 Share Posted June 2, 2022 3 minutes ago, rwdozier said: Couldn't you Build Roof Planes and Retain Manually Drawn Roof Planes? Yes, but they still need to be raised as Eric is suggesting. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted June 2, 2022 Share Posted June 2, 2022 56 minutes ago, solver said: select them and lower Raise using Transform/Replicate. You need to Raise them all 12 inches..... which is easy with T&R use 12" (up) in the Z-Delta ( for down you would use -12" ) Mick. 1 Link to comment Share on other sites More sharing options...
Tony-209 Posted June 3, 2022 Author Share Posted June 3, 2022 Thanks guys, this worked! Link to comment Share on other sites More sharing options...
