BrentJohnJohn Posted May 28, 2022 Share Posted May 28, 2022 Greetings, I am struggling to remove an Invisible Wall - see attached. I have tried everything to delete this and it will not. Link to comment Share on other sites More sharing options...
BrentJohnJohn Posted May 28, 2022 Author Share Posted May 28, 2022 Sorry, I meant to add: when I double click on it, the wall type is "Room Divider". Link to comment Share on other sites More sharing options...
BrentJohnJohn Posted May 28, 2022 Author Share Posted May 28, 2022 I finally figured it out! I needed to add walls around the stair opening. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 28, 2022 Share Posted May 28, 2022 6 minutes ago, BrentJohnJohn said: I needed to add walls around the stair opening. It is still better to keep that and just turn off the layer if you don't want to see it. "if a room is drawn within a larger structure and none of its walls connect to the exterior walls, either directly or indirectly by connecting to walls that do, it is referred to as an “island” room. The program will connect such a room to the larger structure with an Invisible Wall. See Room Dividers and Invisible Walls." 1 Link to comment Share on other sites More sharing options...
glennw Posted May 28, 2022 Share Posted May 28, 2022 You can control that behaviour with the Connect Island Rooms setting: Link to comment Share on other sites More sharing options...
Dermot Posted May 29, 2022 Share Posted May 29, 2022 I recommend that you always leave "Connect Island Rooms" turned on. See my post here for more info: 1 Link to comment Share on other sites More sharing options...
