Entry and garage door
DianeP
11 hours ago, glennw said:
You can get pretty close using the door dbx.
Looks wonderful.  looks like I need to move over to X13.  I have it but have noticed it crashing and my work not being saved, so I move back to x12.
30 minutes ago, DavidJPotter said:
Take a look in the Simpson Door - Thermal French for a door style close to what you want that can be modified and the Coplay Garage Door - Modern Door for close to what you want, all in X12.
Thank you so much.  I would prefer to keep working in x12 on this project until I build a bit more trust in x13.
David is there a way to get it so I can edit the manufacture's door?  I haven't been able to before but thought I would check to see if you found a way.
David,
You got the hinged door OK, but not the garage door.
All done with a standard Chief door.
This will get you going on the garage door.
If you don't check All Glass, only one panel has glass (third panel up from the bottom).
The size of the lights in the garage door is completely configurable:
40819984_ScreenShot2022-05-10at10_02_17am.thumb.jpg.bfd6d921a21e72c6cab27edcd9d620b5.jpg
  • Upvote 2
