X14 Cannot import library download
Electromen
I downloaded two cabinet manufacturers from the CA 3D Library, Quality cabinets and Sorento cabinets. I made sure each was the X14 version.
Windows 11 is up to date and so is CA X14.
From File Explorer I opened Downloads > Quality Cabinets
CA X14 opens but I get the following message: The File Quality Cabinets.calibz cannot be imported in the current view window.  Try importing it into a different type of view.
In Properties for the file, it is associated with X14 and is not blocked
Any ideas why?
Details:
GlobalActionUtilities.cpp (133): Warning #272001021
"The file "QualityCabinets (1).calibz" cannot be imported into the current view window. Try importing it into a different type of view."
05/08/2022 09:42:48 AM
Build: 24.0.3.48 Windows 64-bit
Any ideas why?
Details:
Seems like I remember something about a glitch like this that it wasn’t working to just open it but works by dragging it into Chief with a plan file open.
Probably best to report it either way.
Dragging didn't work.  However, having a plan open and the Library showing, opening the download worked
Thanks for your help.
If it didn't work and you had a plan file open then that is a bug and should be reported.  It works for me but has always needed a plan file open for it to work.  Both ways it should be reported I believe.
I don't think that is a supported method, but should work if Chief is open and a plan open.........
Use the Library > Import Library Option, off the Menu Bar ( Top above Toolbars) I've never had an Issue
and it allows you to select multiple Libraries at the same time.....which are imported one after another if needed.
On a side note there are about 430 additional libraries currently............
Use the Library > Import Library Option, off the Menu Bar ( Top above Toolbars) I've never had an Issue and it allows you to select multiple Libraries at the same time.....which are imported one after another if needed.
In all these years of using Chief, I've never done it from the Library.  I tried your method and it worked well.
Thank You.
