selectbuilder Posted May 5, 2022 Share Posted May 5, 2022 Hello, Im sure there is a thread for this but I cannot find it. I Have imported a prior site plan and need to trace it and then scale my lines. Any help would be greatly appreciated! Thank you for your time Link to comment Share on other sites More sharing options...
Chopsaw Posted May 5, 2022 Share Posted May 5, 2022 First scale the imported plan. Then trace over with cad lines and turn on the Length and Angle settings. Those format options are General Cad Defaults. Let us know if you run into any other issues. Link to comment Share on other sites More sharing options...
Mark3D Posted May 5, 2022 Share Posted May 5, 2022 Watch this you tube video Link to comment Share on other sites More sharing options...
selectbuilder Posted May 5, 2022 Author Share Posted May 5, 2022 58 minutes ago, Chopsaw said: First scale the imported plan. Then trace over with cad lines and turn on the Length and Angle settings. Those format options are General Cad Defaults. Let us know if you run into any other issues. Awesome, Thank you. I will give it a go and be back Link to comment Share on other sites More sharing options...
selectbuilder Posted May 5, 2022 Author Share Posted May 5, 2022 28 minutes ago, Mark3D said: Watch this you tube video Thanks!!!! Link to comment Share on other sites More sharing options...
selectbuilder Posted May 17, 2022 Author Share Posted May 17, 2022 On 5/5/2022 at 2:56 PM, Mark3D said: Watch this you tube video Hello, This video was very helpful but sadly I'm running into some scaling issues and this thought just occurred to me. If my plot plan is in decimal ft does my scaling of say my building to property line work in normal ft? for when I pull over there dimensions for this its off. Thankyou! Link to comment Share on other sites More sharing options...
Chopsaw Posted May 17, 2022 Share Posted May 17, 2022 26 minutes ago, selectbuilder said: If my plot plan is in decimal ft does my scaling of say my building to property line work in normal ft? I don't think you will find that to be a hard and fast rule and it will depend on what the local requirements are and or who you are producing the drawing for. Surveyors will always use decimal feet but if it is the contractor laying out the footings he may prefer to work with feet and inches. Not sure about the dimensions being off if everything is drawn to scale as you may need to post some images or the plan file for that. Link to comment Share on other sites More sharing options...
