LeRoyWells Posted April 25, 2022 Share Posted April 25, 2022 Hi What am I doing wrong Trusses in the back hakf upstairs are not the correct shape or elevationJay and Shellley Jefsen.plan Jay and Shellley Jefsen.plan Link to comment Share on other sites More sharing options...
SNestor Posted April 25, 2022 Share Posted April 25, 2022 @LeRoyWells - All I did was delete all the trusses...and inserted a new truss, used multiple copy. Worked perfectly. I also created new wall types for the attic wall and the gable end wall to not frame...so as to not interfere with the trusses. You'd probably want to make the gable end truss an "end truss" Plan attached; 1468702259_JayandShellleyJefsen - Fixed.plan Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 25, 2022 Share Posted April 25, 2022 its not just the back that has problems if you turn on framing, roof rafters in your layer set you can see you have both rafters and trusses and you have trusses going through top plates. you should select all trusses, open up the dialog and force truss rebuild, and delete the rafters It may be because your ceiling height in the room is 231 but your ceiling plane is:227 you also have a ceiling joist for some reason Link to comment Share on other sites More sharing options...
