Time Tracker Basics
HumbleChief
Thrashing here a bit trying to understand. Let's say I start with an as built plan. 'Save As' As built 2. 'Save As' As Built 3. Then 'Save As' Proposed 1, 'Save As Proposed 2 and so on. It seems that by the time I get to Proposed 6, which is where I am now, it is adding all the time for all the versions. Is this how it works?
  • HumbleChief changed the title to Time Tracker Basics
The help file says that Time Tracker logs times for each plan and layout file separately but when I do a 'Save As' , creating another plan file, Time Tracker carries over the time from previous plan versions as if it is keeping track of time for the project and not just a single file.
Here's 2 pics. One is the original file showing time back to Feb 8th. I do a quick Save As and it's showing this new file back to Feb 8th. as if it's saving time log for the project not an individual file? Not getting it.
2 minutes ago, HumbleChief said:
Thanks Robert! It sure does behave that way but the help file doesn't suggest that. I prefer it this way.
The Help Files are simply stating that Plan and Layout files are tracked independently of each other.  Has nothing to do with Save As.
