Doug_N Posted April 10, 2022 Share Posted April 10, 2022 If I add a conversion unit via the Preferences DBX can I use that unit in Ruby somehow? For example, I have set acre to be 43570 sq ft, and Ha to be 10000 sq m. I can set 10 to sq ft by %10.to_sq_ft% but not %10.to_Ha% nor %10.to_acre% Is there a way to set that up? Link to comment Share on other sites More sharing options...
Chopsaw Posted April 10, 2022 Share Posted April 10, 2022 Let me know if this works for you: Link to comment Share on other sites More sharing options...
Doug_N Posted April 10, 2022 Author Share Posted April 10, 2022 22 minutes ago, Chopsaw said: Let me know if this works for you: Like a charm, thanks for the link. You know, after reading the dialog in that post, I can't see way CA wouldn't allow "area.to_acre". Let's assume that I make a mistake with the unit conversion. If %area.to_acre% produces an erroneous result so would %area.to_s("acre")% Same output, with a lot less typing. CA lets users put in their own conversion factors, as I have done for Ha, hectare and acre. What is the risk to CA? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 11, 2022 Share Posted April 11, 2022 19 hours ago, Doug_N said: If %area.to_acre% produces an erroneous result so would %area.to_s("acre")% Same output, with a lot less typing. CA lets users put in their own conversion factors, as I have done for Ha, hectare and acre. What is the risk to CA? Read through the dialog again. I think I pointed out pretty clearly why Chief does what they're doing. Its not to protect against "erroneous results". Its due to Ruby's naming conventions. Chief will allow for a unit called "Clown Feet" but to_Clown Feet would be invalid Ruby method naming syntax. In fact, there are plenty of OOB units that will not work using to_unit for that very reason that will work just fine using convert_to("unit"). I suppose Chief could probably write some code that would test to see if the unit's name is valid and then create a matching to_unit method but I'm guessing they just went for a one size fits all approach. I personally don't care at all. Link to comment Share on other sites More sharing options...
Doug_N Posted April 11, 2022 Author Share Posted April 11, 2022 4 hours ago, Alaskan_Son said: Read through the dialog again. I think I pointed out pretty clearly why Chief does what they're doing. Its not to protect against "erroneous results". Its due to Ruby's naming conventions. Chief will allow for a unit called "Clown Feet" but to_Clown Feet would be invalid Ruby method naming syntax. In fact, there are plenty of OOB units that will not work using to_unit for that very reason that will work just fine using convert_to("unit"). I suppose Chief could probably write some code that would test to see if the unit's name is valid and then create a matching to_unit method but I'm guessing they just went for a one size fits all approach. I personally don't care at all. I see where you are coming from Michael. From my point of view saving the extra typing would be worth it, as I use area analysis a lot on my projects, and most of that involves units that are not supported by value.to_unit. Typing value.to_s("unit") just adds places where I will make a typing mistake. (I know, a typing mistake while coding? Unheard of.) Besides it would be great to have just one standard way of doing something. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 11, 2022 Share Posted April 11, 2022 38 minutes ago, Doug_N said: I see where you are coming from Michael. From my point of view saving the extra typing would be worth it, as I use area analysis a lot on my projects, and most of that involves units that are not supported by value.to_unit. Typing value.to_s("unit") just adds places where I will make a typing mistake. (I know, a typing mistake while coding? Unheard of.) Besides it would be great to have just one standard way of doing something. Based on your response, I think you're typing way more than you should be. You might consider writing a custom text macro or method that keeps you from re-typing all the time. Link to comment Share on other sites More sharing options...
Doug_N Posted April 11, 2022 Author Share Posted April 11, 2022 2 minutes ago, Alaskan_Son said: Based on your response, I think you're typing way more than you should be. You might consider writing a custom text macro or method that keeps you from re-typing all the time. Yes I suppose I could write a series of macros for the conversions that I do the most. Maybe I should stop whining about this ..... lol Link to comment Share on other sites More sharing options...
