Is there any free online source for Topo Contour lines for use in Chief?
DavidJPotter
I have found USGS maps on line with contours for the areas where some of my projects were located.  Unfortunately, there are no elevations data bases the way I've used those maps.  I just rescale them as best I can and then recreate the elevation contours using elevation lines and points.  Keep in mind that unless you can get a 7.5 minute map, the contour intervals are large.  If the area is not very steep, this method is more or less useless, especially if the property isn't very big.
In Ohio several county auditors provide this data for download.  In our home county they have parcel data and gis data in separate files.  We can download both and import them to give us the topography and lot lines.
I searched Austin Texas and found you can download DWG files of the data at https://austintexas.app.box.com/s/nu5ju1ni2vz0oonm67f014xqdwip526k/folder/42061586880
Here's the main website https://www.austintexas.gov/department/gis-data  It includes some arcgis links which we also find useful.
Hope this helps.
