SKCanada Posted March 16, 2022 Share Posted March 16, 2022 Hello, I am looking to create a decorative wood slat wall divider in a room. Does anyone have tips on how to create it? Thanks in advance! Kimberly Link to comment Share on other sites More sharing options...
winterdd Posted March 16, 2022 Share Posted March 16, 2022 21 minutes ago, SKCanada said: Hello, I am looking to create a decorative wood slat wall divider in a room. Does anyone have tips on how to create it? Thanks in advance! Kimberly Sounds like a polyline solid kind of job. I did that type of wall on a raised beach home to help break wind gusts underneath. Link to comment Share on other sites More sharing options...
ericepv Posted March 16, 2022 Share Posted March 16, 2022 I did one once using a railing. Link to comment Share on other sites More sharing options...
SKCanada Posted March 16, 2022 Author Share Posted March 16, 2022 Thank you!! Link to comment Share on other sites More sharing options...
rgardner Posted March 16, 2022 Share Posted March 16, 2022 3 hours ago, SKCanada said: Hello, I am looking to create a decorative wood slat wall divider in a room. Does anyone have tips on how to create it? Thanks in advance! Kimberly If you are using x13 (can't tell from your signature which version). There is the ability to use lateral framing in wall definitions so you can simply add the slats on the exterior and interior if you want both sides of the wall definition layers setting the size and distance you want to see. You can even add a thin black layer behind the slats so you see black between the slats. Link to comment Share on other sites More sharing options...
