Designer1 Posted February 1, 2022 Share Posted February 1, 2022 Is it just me or is the Material eye dropper broken when it comes to tinting chiefs sand stucco? Usually the material eye dropper works like magic on nearly anything from siding to paint. However when I select any of chiefs stuccos, in particular I was using the sand choices, once you apply a color to it, it erases the texture. I also tried several times to make sure I had the correct "tint" brush roller on and not just applying the color but had the same result. Is anyone else having this happen? Thanks! Link to comment Share on other sites More sharing options...
Renerabbitt Posted February 1, 2022 Share Posted February 1, 2022 32 minutes ago, Designer1 said: Thanks! From memory, the stucco materials have no texture(color.diffuse) map, only a bump map Link to comment Share on other sites More sharing options...
Chrisb222 Posted February 1, 2022 Share Posted February 1, 2022 3 hours ago, Designer1 said: Is anyone else having this happen Yes that's how the Chief stuccos behave. Access the Define Material dialog (many ways to do this- plan materials, wall definition, or click on the wall in 3D using the Adjust Material Definition (rainbow) tool). On the Pattern panel click Material Color and change the color there. It will retain the textured look. Make a copy of it first of you want to keep the original. Link to comment Share on other sites More sharing options...
Renerabbitt Posted February 1, 2022 Share Posted February 1, 2022 @Chrisb222and @Designer1 you can always save all stuccos to your own user library and add a solid color map to the texture designation. This will allow the blend-with behavior to work Link to comment Share on other sites More sharing options...
Designer1 Posted February 2, 2022 Author Share Posted February 2, 2022 Thanks so much for all the help and guidance on this, I appreciate it! Link to comment Share on other sites More sharing options...
SteveNovato Posted February 2, 2022 Share Posted February 2, 2022 This really clears things up for me! I spent over an hour recently, trying to place the stucco color on adjacent wood siding...YouTube, forums, etc. all to no avail. It seemed to me that something so simple would obviously be user error. I have been vindicated! Thank You Link to comment Share on other sites More sharing options...
