Text/Notes column with bullet numbers
ChiefuserMathews
9 hours ago, ChiefuserMathews said:
I am wondering is there an option in CA to continue the text/notes in the next column with bullet numbers? like we do in word
I'm not so sure I understand what you're talking about.  Can you show an example?  Is it the columns you're having trouble with, the bullets, or both?
4 minutes ago, SH_Canada said:
Can this be done, such that if you add a new row in between say 2 and 3, all the other lines will move to the next column, and increment?
Yes and no.  Can be done in layout by sending multiple cropped views of a single column text box. Or in plan by using multiple text boxes and custom macros.  There’s no built in function that will do this automatically in Chief though.
Yes this is a good suggestion.
