mtldesigns Posted January 27, 2022 Share Posted January 27, 2022 Anyone know how to change the material of a sq. half post? I'm using cable as my "rail", so I need a piece at the end to connect to. I didn't want to cut a newel with cap in half.. wouldn't look right. I tried painting also (even though I don't like doing that) to no avail... I will have this scenario in many spots, so trying to avoid doing a poly solid. Link to comment Share on other sites More sharing options...
Dermot Posted January 27, 2022 Share Posted January 27, 2022 You should be able to temporarily remove your library symbol newel, change the material for your parametric newels, and then put the symbol back. You should always report these kind of things to our tech support team. Link to comment Share on other sites More sharing options...
Solution Chopsaw Posted January 27, 2022 Solution Share Posted January 27, 2022 You can go and change your Material Default after the fact but that would be the long way to do it for sure. Not that the half post is the first detail that you would logically think about. 1 Link to comment Share on other sites More sharing options...
mtldesigns Posted January 27, 2022 Author Share Posted January 27, 2022 7 minutes ago, Chopsaw said: Material Default That did it Chop thanks man!!! 10 minutes ago, Dermot said: You should always report these kind of things to our tech support team. I typically ask on here first before going to tech.. It might be I am having a lapse of commons sense, which these guys are quick to point it out. :-) 14 minutes ago, solver said: simple plan not a simple plan... very large file. Link to comment Share on other sites More sharing options...
