Square Half Post
mtldesigns
Go to solution Solved by Chopsaw,
Anyone know how to change the material of a sq. half post?  I'm using cable as my "rail", so I need a piece at the end to connect to.  I didn't want to cut a newel with cap in half..  wouldn't look right.  I tried painting also (even though I don't like doing that) to no avail...  I will have this scenario in many spots, so trying to avoid doing a poly solid.
  • Solution
You can go and change your Material Default after the fact but that would be the long way to do it for sure. Not that the half post is the first detail that you would logically think about. ;)
7 minutes ago, Chopsaw said:
Material Default
That did it Chop thanks man!!!
10 minutes ago, Dermot said:
You should always report these kind of things to our tech support team.
I typically ask on here first before going to tech..  It might be I am having a lapse of commons sense, which these guys are quick to point it out.  :-)
14 minutes ago, solver said:
simple plan
not a simple plan... very large file.
