Missing pattern on material
Gawdzira
I have a stucco texture from the CA library, Stucco -> Sand Finish-Flint. I have added a "sand" pattern to the texture and it does not show up in a vector view elevation. It does show up in the Layout box view. When I print it disappears again. I tried setting the pattern line weight to 30 and it still does not appear. Left image is Layout, Center is pdf, right is vector view in Plan. Computer is is to spec with a 3080 card.
